Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Tool Library Fail
5 REPLIES 5
jtorreDWT4X
232 Views, 5 Replies
Tool Library Fail
Why are my students getting "Failed to import a library" when they import the tools file given by PLTW?
We are using Fusion 360 and when I import the file, I have absolutely no issues but when my students follow the steps they get that error message. Any thoughts?
5 REPLIES 5
kellings
in reply to: jtorreDWT4X
Are the students running the software on a local computer or are they running the online version of Fusion?
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
jtorreDWT4X
in reply to: kellings
They are using their local computer.
MattPerez314
Is the library local on their machine and are they importing it to a local library or cloud library?
kellings
Ok thanks. I'm trying to figure out if maybe it is a permissions setting.
Here is something I just tried that you might want to do instead. I went to to the Fusion preferences --> Manufacture and then I enabled cloud libraries
When this is enabled, in the data panel you will see a folder (towards the bottom) called Assets. In the Assets folder is a CAMTools folder. I uploaded the tool library there instead, and now it is available under the Cloud section of my tool library.
I downloaded a Destiny Tool library from the Autodesk website.
Here you can see the Destiny tool library now appears in my cloud section even thought I didn't uploaded it directly into the Fusion tool library
Kevin Ellingson
jtorreDWT4X
This worked!!!! Thank you!!
You've got Fusion.
