Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Tinkercad Import a Fusion File
2 REPLIES 2
heyrobert
185 Views, 2 Replies
Me again! I recently discovered Tinkercad... and I see that it's owned by Autodesk as well. Tinkercad has a Sim Lab... can you import Fusion 360 models into it? I see that you can import Tinkercad models into 360. I'm surprised something as simple as Tinkercad would have the ability to simulate gravity, etc., but 360 does not. Thanks!
2 REPLIES 2
dan.banach
in reply to: heyrobert
Hi @heyrobert
I moved this topic to it's own post. In Tinkercad, you can Import; STL, OBJ and SVG files.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
heyrobert
in reply to: dan.banach
Thank you!
You've got Fusion.
