Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Temporarily Changing roles in subfolders
8 REPLIES 8
Message 1 of 9
merrittjacob
264 Views, 8 Replies
My students each have their own folder on my team (e.g. Jane). They have edit permissions for their folders. I ask  them to create a subfolder (in their own folder) for each assignment (e.g. folder Jane has subfolder Assgn1).  I understand that any subfolder will carry the permissions of the parent folder, so Jane has edit permission for Assgn1. After they have created their work, and the assignment is complete, I would like to change the permissions of their subfolder (Assgn1) to viewer so they can no longer work on the model in the Assgn1 folder. Essentially enforcing a due date and not allowing any changes.
Will the plan work? Can an administrator change the permissions of subfolder to view only while parent folder has edit permissions?
Thanks.
Meritt
8 REPLIES 8
Message 2 of 9
dan.banach
in reply to: merrittjacob
Hi @merrittjacob
Great question. Yes, a member's roles can be different in subfolders. Below is an image I did to confirm this.
[1-30-23 Update: Currently you cannot change the Role of a subfolder to be different than the Role set from the parent folder]
For the Roles question. At the Fusion Team level, a Team Administrator and Team Member can change members' Roles. This is why I suggest students are assign the Fusion Team Role of Project Contributor (can't add members or change Roles).
Does this answer your questions?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 9
merrittjacob
Thanks for the quick response Dan. It was very helpful.
I tried your suggestion and as you can see from the image, I was able to change roll (Role Details box), but if you look at the background screen you can see the student still is listed as having an editor roll. I plan on checking with the student tomorrow to see if they can do more than just view their files in the Chapter 2 folder. Should the roll in the main screen (shown in the background) update to reflect the Assigned Role rather than the Applied or Inherited Role?
Thanks.
Merritt
Merritt
Message 4 of 9
dan.banach
Hi @merrittjacob
Sorry, I misspoke. The Role of a subfolder cannot be changed. I'll ask the Fusion Data team if this is something that could be changed in the future and if they have another idea.
I'll let you know what I learn.
-Dan
Dan Banach
Message 5 of 9
dan.banach
Hi @merrittjacob
I confirmed with the Fusion Team that subfolder always inherits from the parent folder and the effective role is the higher role. An idea.
  1. Create an Submitted Assignments folder and add all the students with the Role of Editor.
  2. Ensure the students' design files have their name in it
  3. Have the students move their completed design into this folder. By moving the files, the version history should be maintained, except the latest version will change to the date the file is moved.
    1.  Instructions on How to move designs between projects in Fusion 360
  4. After all the files are moved into this folder, remove the Role for all the students in the Submitted Assignments folder.
Could this process help?
Do others have ideas on improving the process to submit assignment files?
-Dan
Dan Banach
Message 6 of 9
merrittjacob
in reply to: dan.banach
Dan,
How about the copy command. If I copy the student folder into a folder that they don't have editor permission for will this achieve the same result. Are links maintained btw the files that are copied from one space to another. Again the goal here is to prevent them from accessing the file after a certain time, but allow them to keep their original for future use/ revision.
Thanks for taking a dive into this.
Merritt
Message 7 of 9
dan.banach
Hi @merrittjacob
You can absolutely use the Copy command. The downside is the version history will be lost. The copied file will only  shows one version. If version history isn't important, Copy would be a solution.
Hope this helps.
-Dan
Dan Banach
Message 8 of 9
merrittjacob
Dan,
Is this something that can be changed in the future? Is it going to be considered or is the "work around", the only solution?
Merritt
Message 9 of 9
dan.banach
Hi @merrittjacob
I raised this as a future enhancement to the Fusion Data Team. Thanks for suggesting this enhancement.
-Dan
Dan Banach
You've got Fusion.
