Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Stange Revolve embedded
5 REPLIES 5
tjburke8BQFK
116 Views, 5 Replies
I have used revolve with good results in the past, but the attached semi transparent Freznel lens has an atypical profile embedded within.  Saving as an STL file failed.  This object is considerably more detailed than others done successfully.  There appears to be something wrong with my sketch as I had difficulty around the solidifying the sketch around the revolve axis.
5 REPLIES 5
dan.banach
in reply to: tjburke8BQFK
Hi @tjburke8BQFK
When I've seen a revolve fail, it's usually because the geometry self intersects. But, it's hard to tell what's happening from the images. Can you export the .f3d file and attach the .f3d file to your reply? Creating a Share Public Link will also work.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
tjburke8BQFK
in reply to: dan.banach
Hi Dan: Thank you for responding.  I will try to include the f3d file
here.  One thing I did which might be the issue is, I modified a solid
bottom Fresnel lens by hollowing out the bottom for better light
transparency. I believe Where part of the original solid lens was
attached to the origin, is no longer attached.  I can always try to
coppy it back, but not sure if this is the issue or not.  Thank you.
##- Please type your reply above this line .
This email has been checked for viruses by Avast antivirus software.
https://www.avast.com/antivirus
dan.banach
Hi @tjburke8BQFK
Thanks for the additional information. Unfortunately, I'm not seeing the .f3d file. Can you log into the forum post, Stange Revolve embedded and reply and attach the .f3d?
-Dan
Dan Banach
tjburke8BQFK
Hi Dan - Failed at sending the file.  Tried a few times, however...  I
ended up redrawing the lens and it came out perfectly. STL fiole is now
on mu desktop ready for slicing.  I need to be more careful when placing
a point on a line that ends up undefined.  This particular design is
somewhat complicated, so paying attention to details is important,
especially making incorrect assumptions when there is no warning is
possible.
I am making 2 red and 2 blue lenses for an old Railroad lamp. Evidently,
replacement lenses are made of unobtainium.
Thank you for your help.  Without your comments I wouldn't have decided
to redraw.
dan.banach
Hi @tjburke8BQFK
Glad I was able to help. Another idea that will simplify the sketching. See if the following helps.
  1. Sketch only the inside or outside of the lens profile and draw a line for the axis of revolution.
  2. Use the Revolve tool on the Surface tab > Create menu.
  3. After revolving the surface, from the Surface tab >Create menu > click the Thicken tool. This will turn the surface body into a solid.
Let me know if this method works for you.
Take care.
-Dan
Dan Banach
You've got Fusion.
