Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
situation where the object is always white
2 REPLIES 2
leducthang32
73 Views, 2 Replies
Hi everybody!.
I have a situation where the object is always white even if I change the material the color doesn't change. Is there any way to fix it to get it back to normal?
Thanks everyone!
2 REPLIES 2
dan.banach
in reply to: leducthang32
Hi @leducthang32
Thanks for posting about your issue. A suggestion and a request.
  1. At the bottom of the screen, under Display Settings, what is the Visual Style set to?
  2. Please try the 3rd Visual Style option; Shaded with Visible Edges Only.
  1. If this doesn't solve the issue, are you unable to change the material in other files or just this one?
  2. If the issue is just with the one file, please export the f3d file and post it with your reply.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @leducthang32
Wanted to check-in and see if your issue was solved with the Visual Style setting?
-Dan
Dan Banach
You've got Fusion.
