Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Silly question about make a hollow body
3 REPLIES 3
marco.sadun
105 Views, 3 Replies
Hello! I have some troubles to understand how to make an cube body, with a hollow with a shape of a cone. Someoine can help? Thank you.
Marco
3 REPLIES 3
o.briggs
in reply to: marco.sadun
No silly questions here! Making a hollow body is very easy, but a lot of people don’t realise! You can use the shell tool within the modify menu to do it! Where as normally you would select an outside face of a body to shell it and leave one side open, if instead of selecting a face on the body, you select the body you want to be hollow from the browser, you can define a wall thickness as usual and end up with a hollow part! It’s always worth doing a section analysis afterwards (inspect menu) to check it is how you want it!
Oliver Briggs
Community Manager - Education
Are you an education user?
Check out our Students & Educators Community
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
o.briggs
hi @marco.sadun
Did we solve your issue?
If so, it would be great if you could mark our reply as a solution!
If not, let us know so we can help you get sorted!
Oliver Briggs
marco.sadun
in reply to: o.briggs
Many thanks! I understood better now how to make those kind of actions!
You've got Fusion.
