Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Share Public Link greyed out
2 REPLIES 2
craigalexander.best
107 Views, 2 Replies
Hello!
Has anyone else been facing an issue with the share public features since the recent update? The feature is greyed out on both Fusion and A360. We have tried all of the work arounds but still no success. This is an issue throughout the whole school.
TIA.
2 REPLIES 2
@craigalexander.best
If you’re using a new Folder-Level project, this is a known limitation, and the team is working on this issue. Here a link to a post where I gave a workaround.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Hi @craigalexander.best ,
Good news, if you are running Fusion 360 release V.2.0.13881 or later, Share File is now enabled for Folder Level Projects.
Note: Member should have Editor or above role to share files.
Geethapriya Shetty
You've got Fusion.
