Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Save button grayed out
12 REPLIES 12
Message 1 of 13
schirmers28H
267 Views, 12 Replies
The save button is grayed out, (I am not education edition) so I am supposed to be able to save, but I can't. All my friends/classmates have no issues, so I am reaching out for solutions.
12 REPLIES 12
Message 2 of 13
dan.banach
in reply to: schirmers28H
Hi @schirmers28H
From the screen capture it doesn't look like you have a valid license of Fusion. Are you a student?
To acquire or renew a Fusion 360 Education license, do the following.
  1. Sign into the Autodesk Education site and if needed verify your eligibility.
  2. On the Individual tab, on the Fusion 360 product card click "Get product".
  1. Then click "ACCESS".
  1. Launch Fusion 360 (if you're running Fusion from a browser, you can cancel the install).
  2. If the Education license does not appear on the top of the screen as shown in the following image, sign out and back into Fusion 360.
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 13
schirmers28H
I do have the education license, which is why I am confused. I have tried updating, logging out and then back in, but nothing works.
Message 4 of 13
dan.banach
Hi @schirmers28H
What is the version of Fuion that is installed? On the top-right corner of the screen click on the ? > About
Can you Export a .f3d file. From the File menu > Export?
Can you try to Reset Fusion from the Fusion 360 Utility Service? See: Overview of Reset Fusion 360 Command from Fusion 360 Service Utility. Since you may have locally cached file, when resetting Fusion, I’d recommend checking the options (Keep offline user cache, Keep user credentials).
Let us know what you find out.
-Dan
Dan Banach
Message 5 of 13
schirmers28H
in reply to: dan.banach
Despite trying all of those steps/options, none of them work. Attracted below is a screenshot of the version. As for trying to export, I am unable to even get to the menu, with export being grayed out.
Message 6 of 13
dan.banach
Hi @schirmers28H
Thanks for the screen captures.
Can you confirm that you're running Fusion on a Mac / Apple silicon computer with an M-series chip?
Is the graphics card driver updated?
Please post a screen capture that shows the entire Fusion screen?
-Dan
Dan Banach
Message 7 of 13
schirmers28H
 I use a apple M1 (2020), with 8 Gb of ram/memory.
Message 8 of 13
kellings
Hi @schirmers28H Could you go to your data panel and take a screen shot with that open and post it here please?
Another possible thing to try. You will find a Fusion 360 Service Utility. You might try using that to run a repair install to see if something wasn't installed correctly the first time.
Kevin Ellingson
Technical Specialist
Message 9 of 13
schirmers28H
in reply to: kellings
I am afraid I already did that, having reset Fusion 360 with the service utility school.
Message 10 of 13
dan.banach
Hi @schirmers28H
Kevin has a great suggestion about the project being the potential cause. Via the Data Panel, can you confirm which Fusion Team and Project are active? This is why Kevin asked for this screen capture.
Under your account, I can see a Closed Project named “New Project” in your instructor’s Fusion Team. With a Closed Project, you can see it in the list of projects, but you need to be invited into this project to save files into it.
Can you create a new Project and try to save a file into it?
-Dan
Dan Banach
Message 11 of 13
schirmers28H
It worked, thank you very much for your help
Message 12 of 13
dan.banach
Hi @schirmers28H
Can you confirm that the project invite was the issue?
-Dan
Dan Banach
Message 13 of 13
schirmers28H
Yes, I had to create my own private group, and after that, I was able to save.
You've got Fusion.
