Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Replace non linked components?
9 REPLIES 9
Message 1 of 10
calle_marlow
279 Views, 9 Replies
Im trying to replace a component in my assemblies however the components are not linked since they were not made in fusion originaly. There is no easy option to replace a non linked component that i have found that doesent include deleting it and replaceing it that way...
Is it possible to link the component to seperate design or is there any other way this can be done?
9 REPLIES 9
Message 2 of 10
kellings
in reply to: calle_marlow
Hi @calle_marlow Here is some product documentation that will show you how you can do this.
Fusion 360 Help | Replace external components | Autodesk
Let me know if that helps,
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 10
calle_marlow
in reply to: kellings
It dosent unfortunately, If the component is not linked you dont get the option to replace component.. this is all i get
Message 4 of 10
kellings
Can you provide more details on what you are trying to do? When I first read your post my assumption was that you had an assembly file and had opened a non-native Fusion file and inserted it into the assembly. Which would link it, unless you broke the link.
Based on your image, you have opened a file and I can see it has one body. I'm not quite following what you are trying to achieve. Can you help fill in some more details for me?
Kevin
Kevin Ellingson
Message 5 of 10
calle_marlow
Yes, in the picure im trying to follow the link you posted. I have a step file assembly with multiple components and i need to change one component basically222.pngfs.png
Message 6 of 10
dan.banach
Hi @calle_marlow
Currently,  I don't believe there is a way to replace internal components. This is a good wish list suggestion.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
Message 7 of 10
calle_marlow
in reply to: dan.banach
It would be! Or a option to relink components to a external design.
Message 8 of 10
o.briggs
@calle_marlow I am curious. Can you not simply edit the design of the component already there? External components can still be edited and it seems the only difference (from looking at it) is the design in the centre. You could re-sketch (or import a dxf) of the central design and extrude cut it into the component already within the assembly?
Oliver Briggs
Community Manager - Education
Are you an education user?
Check out our Students & Educators Community
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
Message 9 of 10
calle_marlow
in reply to: o.briggs
I could do that or delete it and place the new component but that component is in multiple designs, i would have to do that 10+ times...
Message 10 of 10
o.briggs
@calle_marlow Unfortunately I think that may be what is needed here. Whilst there is a lot you can do with an external design there are limitations. If you think you may need to replace it again in the future it may be worth considering re-drawing the design as a Fusion file given that the shape is not too complex! 🙂
Oliver Briggs
You've got Fusion.
