Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Rendering Feature?
2 REPLIES 2
BrandXMetals
112 Views, 2 Replies
Rendering Feature?
Is there anyway to show dimensions while in render mode?
Thankyou in advance.
2 REPLIES 2
dan.banach
in reply to: BrandXMetals
Hi @BrandXMetals
If you're referring to showing the dimensions in a Sketch, in the Design workspace, do the following.
  1. In the Browser, Expand the Sketch folder under the component whose dimensions you want to see.
  2. Right-click on the desired sketch and click Show Dimension.
  3. Repeat step 2 for the desired Sketches.
Note: If you perform a Rendering in the Render workspace, the dimensions will disappear.
Is this what you're looking for?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
BrandXMetals
in reply to: dan.banach
Yeah, I was wondering if you could show dimensions while rendering in render mode. I don't think you can, but thought that I would ask.
You've got Fusion.
