Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
"adsk.idmgr" links are blocked while launching Fusion 360
10 REPLIES 10
Message 1 of 11
braneshlr
994 Views, 10 Replies
We are using Autodesk fusion 360 for all our student laptops, and all laptops are managed by Microsoft end point manager (Intune). now Fusion 360 is not working after new update it shows "adsk.idmgr" links are blocked.
Hope its blocked because of our Intune policy. I added adsk.idmgr also in Intune policy for edge and chrome, even still not working.
10 REPLIES 10
Message 2 of 11
dan.banach
in reply to: braneshlr
Hi @braneshlr
Sorry that you ran into this issue.
For your Intune policy, please add   adskidmgr:*
Let us know if this solves your issue.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 11
braneshlr
in reply to: dan.banach
Hi Dan Banach
Thank you for your support,
I added adskidmgr:* in Intune policy. Not working
and tried like adsk*, adsk.idmgr:*  also Not working.
Message 4 of 11
dan.banach
Hi @braneshlr
Thanks for the update. Can you please try to update the Autodesk Identity Manager. Here is a link to an article that explains the process. Autodesk Identity Manager component update for product versions 2024 and beyond (Windows).
Please keep us posted.
-Dan
Dan Banach
Message 5 of 11
braneshlr
Hi dan banach,
  • Installed IDSDK 1.9.18.0
  • Copy adskidmgr.bat to C:\adskidmgr.bat
  • Executed adskidmgr.reg
  • Added idsdk_edge_ext extension in edge developer mode
  • Try to signin Fushion 360
Output: Working (another policy blocked)
Message 6 of 11
braneshlr
It was working if we allow all web site in Intune using(*)
When we remove that again not working,
I got sucess in my demo lap. now with student laptop its not working
Message 7 of 11
dan.banach
Hi @braneshlr
Sorry to hear that the students’ laptops are not working. To help figure out the issue, can you please attach the Fusion 360 log files from one of the student’s computer? Here is an article that explains the process
How to manually collect diagnostic log files for Fusion 360
-Dan
Dan Banach
Message 8 of 11
braneshlr
Here i added the Log files
Message 9 of 11
dan.banach
Hi @braneshlr
Thanks for the log files. In the WebServices.log file, there are errors stating "Application not installed properly". Could you try to uninstall and reinstall Fusion360?
I also sent the log files to the engineering team to review. I'll keep you posted on their analysis.
-Dan
Dan Banach
Message 10 of 11
dan.banach
Hi @braneshlr
Here is the feedback I received from engineering.
AdskIdentityManager.exe is not being passed auth code through the custom uri scheme. Is the student browser loaded with the extension?
If it is, should be able to see the batch file being launched (can add a pause at the end of the C:\adskidmgr.bat file to confirm).
Hope this helps.
-Dan
Dan Banach
Message 11 of 11
braneshlr
Fusion360 functioned properly following an update to a new version of Autodesk Identity Manager. Although it is blocked by another Intune app locker policy, we are collaborating with Microsoft to find a solution. There is a temporary fix for this issue. We anticipate a new update from Autodesk to address this problem because it would be too challenging to complete this process manually for all 3000+ users.
You've got Fusion.
