Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Question about getting result from probe inspection on HAAS machine
5 REPLIES 5
shin243
172 Views, 5 Replies
Hello guys!
I am trying to get the probe inspection result through net share on HAAS Mill machine.
I can find the result on the left, but I cannot pull up.
Is there anyone what the reason is?
Thank you!
5 REPLIES 5
kellings
in reply to: shin243
Hi. I’m looking into this and I’m hoping I can get one of the members from that team to stop by and help out. It may not be until tomorrow now as those members are based in the UK.
thanks,
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Philip_Hewitt
Hi @shin243@kellings messaged me- I'm part of the team in the UK.
When we import the results file from Fusion Team we filter based on the file extension to try to make sure that you only see files of the right type.  The intention is good- it should make the process smoother and easier- but it's gone wrong here.
The filtering doesn't recognize your files as results files, probably because of the file extension.  Either it's a file extension we didn't expect, or it's a bug and we are missing some file extensions.
Do you know what type of file extension the results file has?
Workaround.  Make sure you have local copy of the results file on your own computer, and use 'Select from my Computer.'  Navigate to the file and import it (the search function here is more transparent and uses *.*)
Please let us know the file extension on your results files, and we will try to improve the selection from Fusion Team.
Philip Hewitt
Product Manager
kellings
Hi @shin243 Did you make any progress on this following what Philip said?
thanks,
Kevin
Kevin Ellingson
shin243
in reply to: Philip_Hewitt
the file extension is .OUT
What kind of file extension are you expecting??
And sorry for replying late!
Philip_Hewitt
Hi @shin243
.txt or .dat will work.
Philip Hewitt
Product Manager
You've got Fusion.
