Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Question about Fillet
1 REPLY 1
snoken1139
85 Views, 1 Reply
Hello
I am new to Fusion 360 and I am wondering how to make the fillet follow the curved top surface?
so it becomes like this:
Tags (1)
Labels (1)
1 REPLY 1
dan.banach
in reply to: snoken1139
Hi @snoken1139
If you're trying to remove an angled slice from the geometry. Please try the following.
  1. Add a Fillet feature the the existing body.
  2. Add and Angled Construction plane starting on the inside vertical edge (will be the sharp edge).
  3. From the Modify panel click on the Split Body tool.
  4. Select the solid body to split.
  5. For the Splitting Tool, in the Canvas, select the angled construction plane.
  6. In the Browser, turn off the visibility of the back body.
Attached is a sample .f3d file that you can you review via the Timeline.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
