Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Problematic patch
1 REPLY 1
carpathianshunting
117 Views, 1 Reply
Problematic patch
Hi!
I have a complex body. The only way to modelling this form is make a patch.
The programe able to create the patch, but it sticks out from the plane.
Is there any way to fix this problem?
I attached the file and some pictures.
Balazs
1 REPLY 1
Hi @carpathianshunting
Looking at your model, the patch looks correct based on the inputs. To control more of the curvature from the edges, uncheck the "Group Edges" option and try different Tangency and Weight options for the edges. If you need more control, you could add an interior Rail or point.
Also note that the Educators forum is intended to help Educators use Fusion 360 in the classroom. If you're an Educator, you're on the correct forum. If not, you can post future messages to the other Fusion 360 forums.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
