Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Problem lofting simple shape to complex shape
2 REPLIES 2
ma4kan
84 Views, 2 Replies
I'm trying to loft the surfaces on the pictures, but any time I try the loft function, it makes the tangent lines to spiral around the model. If you try to arrange them to be simetrical left and right and compile the object it throws an error that the lines are intersecting and no object is created. Can you please help me solve this problem
2 REPLIES 2
kellings
in reply to: ma4kan
You will see little points where the profiles connect. You can drag those points on the profile to determine how the shapes loft together. If you can't find those points I'm talking about, post your file and I'll see if I can help you get the result that you want.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
ma4kan
in reply to: kellings
I refined the model a little bit and tried arranging the point to be symmetrical. The curvature map now shows that
the sides are symmetrical.
But after I hit ok it throws an error that the curves are intersecting and after that when you open Feature editor for the loft, all the point are scrambled and only the two surfaces are visible.
The only way that it works for me is to highlight the "merge" option for Tangent Edges. That way it is close enough to work with the model, but still not as it should be.
You've got Fusion.
