Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Printing at 1:1 scale with Fusion360 Browser Access
9 REPLIES 9
Message 1 of 10
mdooley
275 Views, 9 Replies
I am having students draw Balsa wood bridges on a 1:1 scale in order to build and test the bridges.  We are using Fusion360 Browser Access on Chromebooks.  How can I print/plot from Fusion360 Browser Access on a 1:1 scale?  I have looked through the forum and haven't found what I need.  Thanks in advance.
9 REPLIES 9
Message 2 of 10
kellings
in reply to: mdooley
Hi @mdooley This is now pretty easily done when Fusion is installed on the physical computer you are using. It is also possible to do using Fusion Online, but the workflow is slightly different.
Have a look at this article for the different ways to print from scale. There is a section toward the end on how to print to scale from Fusion Team.
Fusion 360 Calibrating 1:1 Prints – Clint Brown
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 10
dan.banach
Hi @mdooley
To add onto Kevin's suggestion. With the Nov. 28th update, we added the ability to print a drawing to scale. Here is a link to an article that explains the new Print Controls.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
Message 4 of 10
mdooley
Just for clarity, under the File button, Print is not a visible option, and View Detail on Web is ghosted out.
Message 5 of 10
dan.banach
Hi @mdooley
When I log into Fusion online, I see the Print option as shown in the following image. Can you please post a screen capture of what you see? Note, since there is no hard drive, you may be better off following Kevin's suggestion about printing from Fusion Team.
-Dan
Dan Banach
Message 6 of 10
mdooley
in reply to: dan.banach
[image: screenshot-fusion.online.autodesk.com-2022.12.04-19_34_42.png]
Message 7 of 10
kellings
Apologies @mdooley but it appears your screen shot didn't upload properly. Can you try to post it again please?
Thank you,
Kevin
Kevin Ellingson
Message 8 of 10
mdooley
in reply to: kellings
Message 9 of 10
kellings
Thanks for re-uploading the image.
Did you have any luck following the latter part of the link I posted last week on how to print from Fusion Team to do this? Will that method work for you?
Kevin
Kevin Ellingson
Message 10 of 10
dan.banach
Hi @mdooley
Thanks for the screen capture. Looks like you're in the Design workspace, and you cannot print from this workspace. To print, open or create a new drawing.
If needed, you capture an image from the Design workspace.
Does this help?
-Dan
Dan Banach
You've got Fusion.
