Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Post processing for Denford Turn 270 Pro- Error ( Any ideas why?)
4 REPLIES 4
athomasP56VK
181 Views, 4 Replies
Information: Configuration: Denford
Information: Vendor: Denford
Information: Posting intermediate data to 'Y:\Departmental\Engineering\Teaching\KS4 OCR Cam Nat\Eng Manu 18\R111\Fusion CNC\1001.fnc'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, February 8, 2023 9:17:00 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5892.3
Configuration path: C:/Users/4004Anth/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts/denford.cps
Include paths: C:/Users/4004Anth/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts
Configuration modification date: Friday, February 3, 2023 2:26:44 PM
Output path: Y:\Departmental\Engineering\Teaching\KS4 OCR Cam Nat\Eng Manu 18\R111\Fusion CNC\1001.fnc
Checksum of intermediate NC data: 991605389afa350b5ce2dcdf0f61da6a
Checksum of configuration: 4d36de3c444870d6010bdd61dde1685f
Vendor url: http://denford.ltd.uk
Legal: Copyright (C) 2012-2022 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.14337
Error: Turning toolpath is not supported by the post configuration.
Failed while processing onOpen().
Error:
Error: Failed to invoke 'onOpen' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, February 8, 2023 9:17:00 AM
Post processing failed.
4 REPLIES 4
kellings
in reply to: athomasP56VK
Hi @athomasP56VK I'm not quite sure by looking at the error message. Would you be able to post the file so I can have a look? Also, do you know what capabilities the machine has? Such as live tooling, multi-axis etc.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
kellings
Hi @athomasP56VK were you able to export or share a link to your file? If you need a hand with how to do that; please let us know.
Kevin
Kevin Ellingson
athomasP56VK
in reply to: kellings
So it turns out I was using the wrong post, and trying to use a milling post for a turning manufacturing setup.
Called Denford and now I have the correct post for the type of manufacturing I am trying to simulate and export from.
o.briggs
Hi @athomasP56VK sounds like you have got it sorted, but just to confirm and for other users who read this in the future:
Denford have two post processors, one for their routers/mills and one for their lathes. The post processor for their lathes is not currently listed on the Fusion 360 post library (this is being actively worked on). It sounds like they sent you the right post processor which is great!
Oliver Briggs
Community Manager - Education
Are you an education user?
Check out our Students & Educators Community
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
You've got Fusion.
