Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Persistent errors when attempting to verify stedent eligibility
2 REPLIES 2
bhansen1ZUJFL
121 Views, 2 Replies
I am getting about 10 of my 150 students that have this error every time they try to verify eligibility using their student transcript.  If they try 2 days later the same error is appearing.  Is there anything that could be causing this?
2 REPLIES 2
o.briggs
in reply to: bhansen1ZUJFL
@bhansen1ZUJFL
Sorry to hear you are having this issue.
Unfortunately, there seems to be some issue, but unfortunately, I cannot help with it here.
If it is persisting (as it seems to be), you will need to reach out to education support from the following link: https://knowledge.autodesk.com/contact-support
Hopefully, your students will be able to use the trial version of Fusion 360 (if they haven't used it up) which will get them up and running until the issues are sorted.
Oliver Briggs
Community Manager - Education
Are you an education user?
Check out our Students & Educators Community
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
dan.banach
Hi @bhansen1ZUJFL
By chance, did you assign licenses to your students? If so, they won't need to go through the eligibility process. They just need to accept the invitation through an email that they'd receive. Here is an article that walks through this process "Educator’s guide to onboarding and offboarding students"
If your students are getting their own license, then Oliver's suggestion is correct. Our team is not able to fix this issue, but the Education Support Team should be able to. I'd recommend using the Live Chat option.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
