Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Note Line Question
4 REPLIES 4
BrandXMetals
175 Views, 4 Replies
Note Line Question
how do i fix the note lines from distorting like this? See below.
Tags (1)
4 REPLIES 4
dan.banach
in reply to: BrandXMetals
Hi @BrandXMetals,
I cannot reproduce your issue. In Fusion 360, on Fusion Team (shown in the image below), and on the Fusion 360 iPad app, the angled lines look like a vector line. What application are you viewing the drawing in?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
BrandXMetals
in reply to: dan.banach
Forgot to mention, it is after i export it to pdf.
dan.banach
Hi @BrandXMetals
This could be a graphics viewing issue. When I open an exported PDF in Acrobat, at a scale of 66.7%, the angled lines look a little jagged. When I change the viewing scale to 125%, the angle lines look like vector line (see the image below).
There are no settings that I'm aware of to control the export of a drawing to a PDF.
Hope this helps.
-Dan
Dan Banach
BrandXMetals
Thank you for your time. That worked
You've got Fusion.
