Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
not all face groups convert, mesh body to solid body
7 REPLIES 7
Message 1 of 8
tderidder2005
1457 Views, 7 Replies
Hi Guys,
I tried to convert a mesh body to a solid body in Fusion 360. I want to convert it with the prismatic method so I can redesign it relative simple. But if I convert it I keep getting the notification ''Not all face groups of the mesh body could be converted...'' (see pictures) and some faces disappeared. I tried to solve the problem with: combine face goups, repair, create face groups, remesh and reduce but the problem keeps coming back.
I can convert the mesh with the faceted method but than is it a pain to redesign the model. So my question is: does someone know how to solve this problem? Or is simply impossible to convert the body do to the weird shape?
I like to see a answer on my question:)
Thijs
7 REPLIES 7
Message 2 of 8
dan.banach
in reply to: tderidder2005
Hi Thijs,
Can you export the .f3d file and attach this file?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 8
tderidder2005
in reply to: dan.banach
Hi Dan,
First thanks for you answer.
Sure, I can attach the file. I have attached a f3d file, a stl file and a link to the original thingiverse model.
Thijs
link to the thingiverse file:
https://www.thingiverse.com/thing:2872620
Message 4 of 8
dan.banach
Hi Thijs,
I looked at the STL file and I was able to combine a few Face Groups but the file still has because of the self intersecting edges and won't convert to a solid (see the attached file). The downside to STL files is they can have issues that are difficult to fix.
If this is a critical component, you could use the Create Mesh Section Sketch and create sketches and extrude and revolve them.
Hope this helps.
-Dan
Dan Banach
Message 5 of 8
This is a tricky part.  As Dan said some mesh manipulation is tricky on these imported files.
It will take some time but using Mesh sketches then editing the sketch created and use a mesh sketch sketch tools to fit lines, arc and plines to the mesh might help.
As far as converting what you have, you can do it as a faceted solid body then base your reverse engineered version on that, but the mesh sketch has more flexibility.  I tried to remesh and reduce the file without much luck.
Message 6 of 8
Hi Guys,
Thanks for the answers! I have cleaned up some import faces so I can redesign it a bit but I'm gonne try to change the mesh with Mesh sketch so I can convert it.
Thijs
Message 7 of 8
Dear Dan
I also have the same problem. Can you also please help me?
Your Ritvik
Message 8 of 8
colinlamb321
This answer does not seem to apply to my own experience with this problem. I tried mesh sketches but due to the complexity of my geometry, they just didn't work. I need to shell this model and remove certain surfaces, but Fusion seems inadequate to get the job done. Is there another program that can offer me a more straightforward means of converting an STL to a solid body without corrupting it??
You've got Fusion.
