Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Moving black sketch objects
1 REPLY 1
paula.smiarowska
84 Views, 1 Reply
I'm using a voronoi sketch generator plug in. I've got a problem because it's adding new sketch on center of axis and some of them are blue which I can move and some are black and are unable to move. Is there any solution to moving this black sketch? I attached my F3D file.
Tags (1)
1 REPLY 1
Hi @paula.smiarowska
The black geometry is Fixed (can't move). Try these steps to UnFix them.
  1. Edit the sketch.
  2. Window select the black geometry.
  3. With the geometry selected, right-click, and from the menu click Fix/UnFix as shown in the image.
Hope this answers your question.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
