Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Lines infill pattern - where can I find it?
3 REPLIES 3
Nima_khaksar_8190
164 Views, 3 Replies
I wonder how I can do/find the lines infill pattern?
It seems that this pattern is not listed under volumetric lattice. How do I go around it or is there any shortcut that I can use to model this infill pattern?
3 REPLIES 3
Hi @Nima_khaksar_8190
From your description, I'm not sure what you need help with. Can you tell us more about what you are trying to do and is while using the Volumetric Lattice tool? A screen capture would be helpful.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
I have designed a specimen in fusion360 to perform FEM-analysis and what I need help with is how I can apply the lines infill pattern to my specimen.
FYI: There is an infill pattern in CURA called "lines" and I want to apply that to my specimen.
How can I do that?
Here is an image of the gyroid pattern in F360:
I'm not aware of a way to reuse the infill pattern from a 3D Printer slicer. Have you tried Fusion 360's Volumetric Lattice tool? With this tool you can create custom shape that may give you what you need. To use Volumetric Lattice tool, you'll need to acquire the Product Design Extension (Autodesk Education accounts can access for free).
Autodesk Education Accounts - Process to Access Extensions
Educations accounts can access the Extensions for free by doing the following:
  1. On the top-right side of the screen click Extensions
  1. In the Extension Manager dialog box, click on the desired Extension
  1. On the top-right corner of the screen click on Start Access
  1. Note: The Extension will need to be renewed every 30 days (follow the same process).
Hope this helps.
-Dan
Dan Banach
You've got Fusion.
