Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Laser cutting of engraving with Fusion 360
4 REPLIES 4
ogudhdude
309 Views, 4 Replies
Is fusion 360 could be use for laser cutting or engraving?
and, laser cutting or engraving need 3D design or 2D?, i mean, is the design must be extrude or it can only 2D drawing?
4 REPLIES 4
kellings
in reply to: ogudhdude
Hi @ogudhdude. 2D entities can be selected in CAM operations on 3D objects. I frequently engrave 2D text on my CNC mill. I just gave it a test and was able to to add a laser toolpath to outline and centerline text in Fusion, with some edits to entry/exit of the toolpath.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
kellings
I should also note that Fusion CAM was designed to work with 3D objects. So while it is possible to only use 2D geometry, I highly recommend that you create a 3D solid of the body you want to machine.
Kevin Ellingson
dgmc
So lets break out 3 different operations.
2D cut; Fusion does this well
2D line engrave (similar to cut, just a mark that follows a line) Fusion can do this.
Raster image engrave. Fusion cannot do this that I know of.
That would be a feature we would like to see for laser cutters in particular.
Perhaps the "canvas" feature could be exploited in some way to support it
dan.banach
in reply to: dgmc
Hi David,
Not an in-product solution, but to convert a raster image to a dxf file, I've used Convertio. Then insert the dxf file.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
You've got Fusion.
