Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Jointing a Geneva Mechanism Help Please
4 REPLIES 4
hjacksonHFWA5
138 Views, 4 Replies
I have created a Geneva Mechanism (as part of a series of Mechanisms for my students to model for a BTEC CAD assignment) but I am struggling to get the two cogs to rotate correctly when the handle pin engages with the slot. I have tried a number of joint options but to no success. Either the slotted wheel does not rotate correctly, or the drive wheel just ends up locked. Can anyone advise please. See Power point picture
4 REPLIES 4
dan.banach
in reply to: hjacksonHFWA5
Hi @hjacksonHFWA5
@Great question. If the design is 100% correct, creating a Contact Set should work.
Please attach the .f3d file and we can take a look at it.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @hjacksonHFWA5
I found a Geneva gear model from one of my previous books. Open the attached .f3d file and you can see that I was able to get the mechanism to work using a Contact set.
Please let me know if you have any questions.
-Dan
Dan Banach
hjacksonHFWA5
in reply to: dan.banach
Brilliant Dan
Thanks for that.
Never used contact sets before so will have a delve and a try.
That is so good. It was doing my head in!!!
U R a saviour
Harvey
dan.banach
Hi @hjacksonHFWA5
Glad to help. One suggestion. When creating the Contact Set, only add components that will need to interact with each other. This will help performance.
Please keep us posted on your success.
-Dan
Dan Banach
You've got Fusion.
