Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Is there a way to see who is the author of a public link?
2 REPLIES 2
ammon.mills
91 Views, 2 Replies
I have my students turn in their work to my by sharing a public link.  Lately, I've found a few that are giving each other their work.  Is there a way to see who is the author of a public link?  Is there a better way I should have them turn in their completed projects?
2 REPLIES 2
leowarren34
in reply to: ammon.mills
Hi @ammon.mills,
Depending on your class sizes, it might be worth looking at Fusion Teams as you provide students with their own little area to which you can control access. It does take a little bit of setup and it has been a while since I've used it but it's been really good for organising this sort of thing.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
dan.banach
hi @ammon.mills
The downside the Share Public Link is there is no file history. As Leo mentioned, by inviting students into your project, on your Fusion Team, you'll be able to track every students progress (every save creates a version and is labeled with who saved the file). Here is a link to an article that explains the new Folder-Level Projects. In the article there is a link to a webinar that we did in January
Note: Share Public Link is not currently available for Folder-Level Projects, but the team is working on this.
Let us know if you have any questions.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
