Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Is Fusion 360 Machining Extension Free for Educators?
6 REPLIES 6
license_manager79PGU
892 Views, 6 Replies
Hello, I was wondering if Fusion 360 Machining Extension free for educators or has to be purchased?
I'm getting toss around from the commercial and education side of Autodesk trying to find my answer.
Thank you in advance.
6 REPLIES 6
Hi @license_manager79PGU  Yes, the machining extension is included for education. You still have to enable. Go to the solution for this thread and you will see how you can access the machining extension as an educator.
Solved: Re: Can Educational License use the new Plastic Function? - Autodesk Community - Fusion 360
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Awesome, thankyou so much @kellings. I been waiting for a response form Autodesk Education for days on my case but it looks like using the forum is much better.
Glad you got it sorted. When you run into issues, come back and let us know. Tell your colleagues about the forums too if you could. We want to help all those in education to be successful.
Kevin
Kevin Ellingson
@kellings / @LeoWarren-EDU ,
Kevin / Leo,
I hope you can clarify please.
Are the Fusion 360 Extensions available to educators? I just signed-in today and the website reports free to access for 30 days. That would be difficult to show these tools during a full semester if they time-out after one month.
Thank you for your time and attention. I look forward to your replies.
Jerry
Hi @JBernsLM
Educations accounts can access the Extensions for free by doing the following (The Extension will need to be renewed every 30 days, follow the same process).
  1. On the top-right side of the screen click Extensions
  1. In the Extension Manager dialog box, click on the desired Extension
  1. On the top-right corner of the screen click on Start Access
The Extension will need to be renewed every 30 days (follow the same process).
Dan Banach
Sr. Technical Manager & Community Manager
@dan.banach,
Thank you for the confirmation. I could not find any information in writing that the extension could be renewed every 30 days.  This will be very helpful. Thanks again, Dan.
Jerry
You've got Fusion.
