Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
I cant put holes in my toolpath.
1 REPLY 1
rowdyiraspeaksrow
62 Views, 1 Reply
im trying to use the fabrication so I can cut a shock bracket for a trailing arm out on a plasma table, but it wont let me put the hole for the shock bracket on the toolpath I have cut 100s of things with fusion and it has only done this a couple of times.  usually, I find a way around it but I'm struggling this time so could someone please help?
1 REPLY 1
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
You've got Fusion.
