Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
i can't change from box display into smooth display
7 REPLIES 7
Message 1 of 8
omar_mostafa1
152 Views, 7 Replies
i can't change from box display into smooth display , i tried many tools like repail body and auto repair but still in box display
7 REPLIES 7
Message 2 of 8
kellings
in reply to: omar_mostafa1
How are you attempting to switch between box and smooth mode?
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 8
omar_mostafa1
in reply to: kellings
through dispaly mode or alt 1 and alt 3
Message 4 of 8
dan.banach
Hi @omar_mostafa1
It's possible that the surfaces are self-intersecting or have another issue. Please start a new design and in the Form environment, create a simple primitive shape and see if you can switch between the Display Modes.
Keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
Message 5 of 8
omar_mostafa1
in reply to: dan.banach
i can't clearly understand you but unfortunately i can't even finish the form i think there is a problem in it but i can't define it. if it is suitable for you can i send you the link of the project to check it ??
Message 6 of 8
dan.banach
If you can't finish the Form, Undo back until the form is in a stable state.
To verify that this issue is for a specific design, do the following.
  1. Start a New Design file.
  2. Click Create Form.
  3. Create a Box.
  4. Change the Display Mode.
Hope this helps.
-Dan
Dan Banach
Message 7 of 8
omar_mostafa1
i can't Undo back because i saved the project as it is so when i open it , it is directly open the latest form which i can't finish it or even undo back .
Message 8 of 8
dan.banach
Hi @omar_mostafa1
Thanks for the update. Here is a link to an article that explains how to fix Form issues.
Keep us posted on your progress.
-Dan
Dan Banach
You've got Fusion.
