Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
I can not get my work to save it in a PDF format.
2 REPLIES 2
jaxbuddie
149 Views, 2 Replies
I've asked a few different times and each time I get this. see attachment.
How can I get my project to build a pdf document of my project.
2 REPLIES 2
kellings
in reply to: jaxbuddie
Hi @jaxbuddie Are you a registered student in an educational program or an instructor?
The reason I ask is that based on your screen shot, you are using the Personal License which is meant for hobbyists and has some limitations such as only 10 editable files and the ability to not create a PDF. If you are a student, you can go through the student verification process where you will get access to the education license of Fusion which doesn't have any limitations.
You do need to go through a verification process to ensure you are a student before you can access the educational version.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
kellings
Hi @jaxbuddie Did you have a chance to look at my reply? Do you qualify as a student in this scenario?
Kevin
Kevin Ellingson
You've got Fusion.
