Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How to copy sketch?
1 REPLY 1
memolinin
55 Views, 1 Reply
How to copy sketch?
Hi, I cant copy and paste sketches.
Old guides are not helping. There is no copy option. I can only see Move/Copy option together. When I choose that, moving indicators are showing and there is no copying.
How to I copy and paste sketches?
Tags (2)
1 REPLY 1
dan.banach
in reply to: memolinin
Hi @memolinin
Please try to the following steps to Copy sketch data.
  1. Make the Sketch active that contains the geometry you want to copy.
  2. Either select the specific geometry that you want to copy, or if you want to copy the entire sketch, don't select anything.
  3. In a blank area, right-click and click Copy from the menu
  4. Finish the Sketch.
  5. Create a new Sketch.
  6. In a blank area, right-click and click Paste from the menu
    Does this helps.
    -Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
