Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How do i make a 3d shape from its base Faces
1 REPLY 1
lwhittakerpro
100 Views, 1 Reply
I am trying to make a 20 sided dice and trying to learn the software in general. Is there a way to take all of the different faces that make up an object and "fold" them together to form the final 3d shape? Looking at a d20 it is 20 identical equilateral triangles aligned edge to edge in a 3d pattern: i had planned to make my 20 triangles and attach them edge to edge "folding" it into the final shape. I can sort of do this with the surface workspace where i can line up all of my triangles and then use the rotate transformation to get them almost in shape, but i cant get the edges to actually line up.
1 REPLY 1
dan.banach
in reply to: lwhittakerpro
Hi @lwhittakerpro
Here is a YouTube video that goes through the creation of 20 sided dice.
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
