Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
how do i change background in animation
3 REPLIES 3
ibash959
158 Views, 3 Replies
how do i change background in animation as the other forum on here doesnt allow me to have a video. i click render on fusion then theres a video option i click that and press render then it just gives me a picture and not a video. can someone tell me why this is?
3 REPLIES 3
dan.banach
in reply to: ibash959
Hi @ibash959
Can you clarify that you’re in the Animation workspace? Can you please attach a screen shot of what you’re seeing? I’m not sure what you mean by can’t attach a video to the forum. When typing your post, below the text area, there is a Drag and drop area that allows you to attach files.
thanks,
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
ibash959
in reply to: dan.banach
its the fact that i cant change the background color in render section. when i press render as a video it just gives me a picture
dan.banach
Hi @ibash959
Can you attached the .f3d file as I'm still not sure what you are capturing a video from. Are you trying the create a video from an Animation? If so, there is a Publish tool in the Animation workspace.
Also, note that Education licenses of Fusion is limited to 15 or 16 cloud credits per job. The screen capture shows 75 cloud credits are required. Try reducing the size and quality of the rendering job.
Hope this helps.
-Dan
Dan Banach
You've got Fusion.
