Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Help! Tried finding Project to surface but failed.
1 REPLY 1
yang.ziyiABDMG
88 Views, 1 Reply
Please help me!
Where can I find it? Is my shape unavalible for it?
Tags (2)
1 REPLY 1
dan.banach
in reply to: yang.ziyiABDMG
Hi @yang.ziyiABDMG
To project geometry onto a surface. Follow these steps.
  1. Create the geometry that the geometry will be projected onto.
  2. Create a new sketch and draw the geometry that will be projected.
  3. Finish this sketch.
  4. Create a new sketch. (this will be the sketch that the projected geometry will be created on).
  5. While in the sketch, click on the Create panel > Project / Include > Project To Surface.
  6. Select the face the geometry will be projected onto.
  7. In the Project To Surface dialog box, on the Curves section click Select.
  8. In the canvas, select the geometry to project.
  9. Select the desired Project Type option.
  10. Click OK.
Please let me know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
