Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Head of D&T and Lead Practitioner for Trust
2 REPLIES 2
drbausor
138 Views, 2 Replies
I've started to get a pop up box called - Authentication Required
The server iboss proxy-caching web server requires a username and password
The software then freezes and I can't use it.
Very frustrating
2 REPLIES 2
edcharlwood
in reply to: drbausor
Did the link I sent over Twitter help Dave?
Ed
dan.banach
Hi @drbausor
Thanks for posting your question. I believe this message is about your network. A few questions and suggestions.
  1. Can you try to connect to a different network / Wi-Fi (a home network).
  2. Did this issue just start?
  3. Are others at your school getting the same message?
  4. Did your IT Admin change any network settings?
  5. Can also look at your virus software. Here is an article that goes through the details.
  6. Ensure the network ports, domains, and proxy server options are set correctly.
  7. Try restarting your router. This should clear any cached data.
  8. If needed, you can change how Fusion's looks at your network. On the top-right corner click on your profile picture > Preferences and in the dialog, on the left side,  click on Network.
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
