Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
HAAS TL2 MACHINE, DRIVER, AND POST PROCESSOR
5 REPLIES 5
bradleywilley
234 Views, 5 Replies
DOES ANYONE KNOW WHY THERE ARE NO HAAS TOOL ROOM LATHE MACHINES, POST PROCESSORS, DRIVERS FOR DOWNLOAD THAT ARE CONFIGURED BY/FOR FUSION 360 BY THERE TEAM? I CANT FIND A SETUP SHEET THAT WILL WALK YOU THROUGH THE GENERIC SETUP FOR A HAAS TL2 LATHE. I FEEL LIKE HAAS IS BIG ENOUGH THEY WOULD HAVE THERE LATHE MACHINES IN THE SYSTEM BUT MAYBE I AM MISSING IT? THANKS
5 REPLIES 5
kellings
in reply to: bradleywilley
Hi @bradleywilley Can you clarify what you mean by a driver?
You won’t find this machine for machine simulation yet because lathes are not supported currently for machine simulation.
thanks,
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
CGBenner
@kellings
Sorry to butt in, but Kevin... can you please contact me? Slack would be acceptable....   TX!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
bradleywilley
in reply to: kellings
WAS LOOKING FOR THE POST PROCESSOR INSTEAD OF USING A GENERIC ONE?
kellings
Hi @bradleywilley I don't believe there is a specific processor for the TL lathes. I've put in in inquiry with the Autodesk Post team to be sure on that.
Kevin
Kevin Ellingson
kellings
Hi @bradleywilley It has been confirmed. This is the post you want to use with that lathe
https://cam.autodesk.com/hsmposts?p=haas_turning
Kevin
Kevin Ellingson
You've got Fusion.
