Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Grain direction different on each side of the body/component
2 REPLIES 2
jagust
101 Views, 2 Replies
If I apply the material/appearance, the grain direction is different on both sides of the body/component.
2 REPLIES 2
kellings
in reply to: jagust
Hi @jagust Here is something you can do for this.
Open appearances.
Duplicate the appearance you have applied
Edit that duplicated appearance and change the rotation angle by 90 degrees
Apply that new appearance to only the face you need to have adjusted.
That should then give you the same grain direction.
Let me know if you need any further help with this or if you were able to resolve it.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
jagust
in reply to: kellings
Thank you
You've got Fusion.
