Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Giving constrains making blue lines black
2 REPLIES 2
raspeanna
156 Views, 2 Replies
I'm quite new to fusion 360 and I a trying to make constrains to my sketch, so the blue lines become black. I watched some videos but it's not really working for me. I know i have to give some more dimensions, but i can't really get the dimensions how I want too.
Would appreciate some help,
Labels (2)
2 REPLIES 2
dan.banach
in reply to: raspeanna
Hi @raspeanna
Thanks for posting your question. From your image it appears that the sketch is not fixed to the Origin point (0,0). Try adding a Coincident constraint to a point on the sketch to the origin or add two dimensions as shown in the following image.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
raspeanna
in reply to: dan.banach
Thank you this helped a lot!
You've got Fusion.
