Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Generative design structural loads and constraints
1 REPLY 1
m_javadiFMN5N
72 Views, 1 Reply
Hi
I have two questions about the structural loads.
1) What is the difference between having multiple loads defined as opposed to one single load (a result of all loads)?
2) What does exactly "structural constraints" do?
Thank you
1 REPLY 1
dan.banach
in reply to: m_javadiFMN5N
Hi @m_javadiFMN5N
Great questions.
When setting up a Generative Design study, a Load Case is all the applied load at one point in time. You can have as many loads applied. If a different load is occurring at a different point in time, you would create another load case.
A constraint lock a one or more faces in place. At lest one face needs to be constrained, otherwise the applied force(s) would just move or rotate the part.
The image below shows a Generative Design Study (1) with multiple Load Cases (2), (5) and (6) and multiple loads (3) and (4).
Here is a link to a few Generative Design tutorials that will help.
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
