Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
G Code error
6 REPLIES 6
jdsmit2003
151 Views, 6 Replies
G Code error
I'm trying to generate G Code for a CNC project and get the following errors:
Error: ReferenceError: createOutputVariable is not defined
Error at line: 142.
Has anyone encountered this error?
6 REPLIES 6
kellings
in reply to: jdsmit2003
Hi @jdsmit2003 Any chance you can share the file and let me know what post you are using so I can check this out?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
jdsmit2003
Here is one of the files I was working with.  I have a Millright CNC machine, and use grbl post.  It worked before my computer was upgraded to Windows 11.  I'm also now unable to open files previously created in Fusion 360.
kellings
Hi @jdsmit2003 I opened your file, but it has no setups or toolpaths. Did you possibly upload the incorrect version of the file?
Kevin
Kevin Ellingson
jdsmit2003
in reply to: kellings
Here is the Fusion model and the error log.  Thanks for helping.
kellings
Hi @jdsmit2003 Do you get the error while posting? I was able to post your file without issue.
I'm trying to figure out where things are going wrong for you.
Kevin
Kevin Ellingson
jdsmit2003
The error pops up during the Post process.
You've got Fusion.
