It has been a headache. For the most part I have no issue posting an OP to ngc for linux, I go and the machine recognizes the code just fine and it works. But for some reason it will not recognize certain files as having the tool table added to them. I have gone back and re added different tools to the library many times, with no avail. When i first had the issue I created a library and problem solved, then when I had it again, I added a tool to the library I had created and problem solved, now, after many frustrating times of failing even when I did the previous, I have no clue what the hell this program wants from me to get the **** tool into the code. I am willing to write the tool into the code now myself if I have to, it is only one tool, how is it fusion cannot add one tool to the code that requires that tool to work. How is it missing the tool table. That is like its main job, to add tools to the code as needed, otherwise the whole software is bogus and pointless, this isnt a bug it is a complete failure. It is making me go towards mastercam now, because I cant even use the software to get the process done. Soooo frustrating, literally loosing hair because of the mindlessness involved in how this can even be happening.
