Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Fusion 360
4 REPLIES 4
heyrobert
165 Views, 4 Replies
Fusion 360
Just downloaded Fusion 360 and a book from Ascented. For a basic example... will I be able to animate a box on a conveyor belt in 360? I believe Inventor calls it motion dynamics... and uses gravity to where the box would fall off at the end. I want to show how a sphere would be picked up and moved by a part and flow along and fall down and bounce off obstacles in its way. Is that asking for too much in 360? Am I making sense? Thanks in advance!
4 REPLIES 4
dan.banach
in reply to: heyrobert
Hi @heyrobert
Good question. Fusion does not yet have Dynamic Simulation. Inventor would be the solution for this scenario.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
heyrobert
in reply to: dan.banach
Oh, ok... bummer. Is there a plug-in by chance? If not, tell Autodesk to hurry up and include Dynamic Simulation in 360. :o) Thank you so much for your reply, I appreciate it!
dan.banach
Hi @heyrobert
I'm not aware of a Dynamic Simulation plug-in for Fusion.
Does anyone have any insights to a Dynamic Simulation plug-in for Fusion?
-Dan
Dan Banach
heyrobert
@dan.banach wrote:
Hi @heyrobert
-Dan
Thanks - yet again - Dan!
You've got Fusion.
