Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Fusion 360 Crashing on Mac
12 REPLIES 12
Message 1 of 13
Gig23
264 Views, 12 Replies
Please can you advise on the following, my Fusion 360 keeps on crashing if I use it on my Mac.
I have tried to re-install it at least 50x times but it is not working at all. Please can you kindly re-direct me to the relevant department.
Report no. 323402071
[Graphical user interface, text, application Description automatically generated]
12 REPLIES 12
Message 2 of 13
o.briggs
in reply to: Gig23
Sorry to hear that it keeps crashing!
Firstly, at what stage does it crash? And which version of Fusion are you using?
You can create a ticket to request assistance from support but before you do that let’s see if we can find a solution ourselves!
Oliver Briggs
Community Manager - Education
Are you an education user?
Check out our Students & Educators Community
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
Message 3 of 13
dan.banach
in reply to: Gig23
Hi @Gig23,
If Fusion 360 is crashing on launch, here is an article that has steps to try.
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 4 of 13
Gig23
in reply to: dan.banach
Hi Dan
I have tried that trouble shoot but it is still crashing at startup, I have to repair it everytime
[Graphical user interface, text, application, chat or text message Description automatically generated]
Message 5 of 13
dan.banach
in reply to: Gig23
Hi @Gig23
Thanks for the going through the list of possible solutions. Can you verify that your Mac is up to date? This could be related to a Catalina Security Update 2021-008 which fixed a  WebGL and OpenGL issue.
-Dan
Dan Banach
Message 6 of 13
Gig23
Hi Dan
I can confirmed my Mac is definitely UpToDate.
And it is a M1Max with 64GB ram top of the line spec, the hardware are more than sufficient.
I have to run the repair tool everyday and everytime before I use Fusion 360 which is very annoying, please advise
[Graphical user interface, text, application, email Description automatically generated]
Message 7 of 13
dan.banach
in reply to: Gig23
Hi @Gig23
Sorry you're still having this issue. To help determine what is goin on, can you try the following?
  1. Does Fusion run OK after running the repair?
  2. What version of Mac are you running and what is the chip set of your Mac?
  3. This could be a network setting. Can you check that the correct ports and domains are set for Fusion 360 . Here is a link to a document that covers the step....
  4. If you disconnect internet and launch Fusion, does Fusion launch?
  5. If you're still having the issue, can you please collect the Fusion 360 log files and send them to us?
While we figure this out. Can you try to run Fusion 360 from a browser by going to https://fusion.online.autodesk.com and sign in with your Autodesk Education ID (same email that you log into Fusion 360 with).
Thanks for your patience as we work through this issue.
-Dan
Dan Banach
Message 8 of 13
Gig23
Hi Dan
Please find the log files attached
Message 9 of 13
dan.banach
in reply to: Gig23
Hi @Gig23
I'm not seeing the log files, they may be to big for the attachment.
Have you tried the first 4 steps I list above?
-Dan
Dan Banach
Message 10 of 13
dan.banach
in reply to: Gig23
Hi @Gig23
We suspect this issue could be related to the Application Support folder (AdSSO). Can you please go through the steps that are described in this article?
Please let me know if this solves the issue. Thanks for your patience as we figure this out.
-Dan
Dan Banach
Message 11 of 13
o.briggs
Hi @Gig23
I just wanted to check in! We haven't heard back in a little while now, did your issue get resolved?
Thanks!
Oliver Briggs
Message 12 of 13
Gig23
in reply to: o.briggs
Hi there,
The same issue has come up again. Fusion 360 is crashing again !
Message 13 of 13
kellings
in reply to: Gig23
Hi @Gig23 sorry you are running into this.
Can you resolve the problem by following the same steps that resolved this for you the last time? or is this a different issue?
Kevin Ellingson
Technical Specialist
You've got Fusion.
