Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Fusion 360 Black on start and crashes
12 REPLIES 12
Message 1 of 13
realseanlao
377 Views, 12 Replies
Every time I start up Fusion 360, it's a black screen and becomes unresponsive, and crashes. I have tried re-installing and restarting but it's not working.
Tags (1)
12 REPLIES 12
Message 2 of 13
dan.banach
in reply to: realseanlao
Hi @realseanlao
Sorry you’re having this issue. Did this just start happening? Here is a link to an article that lists a few solutions to try.
Keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 13
realseanlao
After trying both methods, nothing seems to be working
Edit:
When I disable my display it works, but when I enable my display driver it doesn't work anymore (also when its disabled its stuck on the splash screen)
Message 4 of 13
dan.banach
Hi @realseanlao
Thanks for trying the suggestions in the article. A few additional questions / suggestions.
  1. When did this start to happen?
  2. Please confirm the version of Fusion 360 that you’re running. While in Fusion 360, on the top-right corner of the screen click ? > About.
  3. Run the Fusion 360 Service utility to Rest Fusion. Here is a link to instructions on how to run the Service utility.
  4. Have you updated the video driver?
  5. Are all Windows updates installed?
  6. Restart your computer and then launch Fusion.
  7. To see if this issue has to do with the install. Try to run Fusion 360 from a browser (Chrome is preferred) by going to https://fusion.online.autodesk.com and sign in with your Autodesk Education ID (same email that you log into Fusion 360 with).
Keep us posted.
-Dan
Dan Banach
Message 5 of 13
realseanlao
I think it has a problem with the installation because it seems to be okay while in the browser.
But after unistalling and reinstalling nothing seems to be working still.
Message 6 of 13
dan.banach
Hi @realseanlao
Thanks for confirming that the Browser access works. This could still be a graphics issue. Were you able to try the other items in the list above? Do you have a graphics card and onboard graphics on your computer?
-Dan
Dan Banach
Message 7 of 13
realseanlao
Hi
I was able to access the Service utility but after resetting Fusion, nothing changed. I also checked my Windows update but everything seems up to date. I have a graphics card on my computer and a Ryzen 5 5600X which I don't believe has integrated graphics, and this started to happen around 3 days ago.
Message 8 of 13
dan.banach
Hi @realseanlao
Let's go back to when you disabled the displayed graphics, this is the onboard graphics. And Fusion launched but then stuck on the splash screen. A few more suggestions.
  1. With the onboard display card disabled, try to running Fusion 360 as administrator. When launching Fusion 360, right-click on the Fusion 360 icon and from the menu click Run as administrator.
  2. Something could have changed with you antivirus. Ensure Fusion 360 is unblocked. Here is a link to an article about configuring antivirus to allow Fusion to run
  3. Here is a link to an article that has suggestions for the stuck splash screen.
  4. Try to rerun the Service Utility and run the Repair tool.
Keep us posted.
-Dan
Dan Banach
Message 9 of 13
realseanlao
I believe this is a graphical issue because everything seems OK after swapping to another computer, but disabling the graphics card appears to have no effect.
Message 10 of 13
dan.banach
Hi @realseanlao
Sorry that you're still having this issue. Please try the steps that are outlined in this article about Fusion 360 not responding.
Let us know if these suggestions help.
-Dan
Dan Banach
Message 11 of 13
dan.banach
Hi @realseanlao
I wanted to confirm that you tried the variable option?
Add an Environment Variable:
  1. In the Windows Control Panel, search for "Environment Variables".
  2. Click "Edit the system environment variables".
  3. At the bottom of the System Properties dialog, click "Environment Variables...."
  4. Under "User variables for <user>", click "New".
  5. Enter "QT_OPENGL" within the Variable name.
  6. Enter "angle" within the Variable value.
  7. Restart Fusion 360.
  8. If the setting causes further issues, repeat steps 1-3.
  9. Edit the "QT_OPENGL" variable, entering "software" within the Variable value.
  10. Restart Fusion 360.
  11. Update Fusion 360 to latest available build.
  12. Delete the system environment variable created above.
-Dan
Dan Banach
Message 12 of 13
dan.banach
Hi @realseanlao
Wanted to check-in and see if you were able to solve the black screen issue?
-Dan
Dan Banach
Message 13 of 13
realseanlao
Thanks a lot, using the last method you mentioned I was able to fix it! Sorry for the late response.
You've got Fusion.
