Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Fluid Generative DESIGN
2 REPLIES 2
michel_mouakar_24
141 Views, 2 Replies
I am designing a hydraulic system, when i was designing it elbow by elbow the software seemed to work without errors but when i integrated the whole hydraulic system as fluid path this error appeared.
So, the problem might be a convergence stuff or another form of errors ?
2 REPLIES 2
Hi @michel_mouakar_24 -
Are you able to post some images of the setup before and after the additional of the whole system? I am guessing that the additional complexity has created some issues in a couple possible areas.
1. There needs to be line of sight between the preserves. If you added obstacles that could now be obstructing preserves from seeing each other, a starting shape will be required.
2. The overall complexity of the system may be so large that the resolution settings can no longer properly capture all of the preserves and obstacles.
Seeing the model will definitely help us provide some next steps.
Mike Smell
Sr. Product Manager, Generative Design
Hi @michel_mouakar_24 Were you able re review the reply that Mike provided? Can you provide more details about your issue?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
