Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Finding an area
1 REPLY 1
agareau
70 Views, 1 Reply
Finding an area
Is there a command or an easy way to obtain the area of a cross-section of a given "Section Analysis" ?
1 REPLY 1
kellings
in reply to: agareau
Hi @agareau. Not in the section analysis command, but you can create a plane where you want that section to be. Then you can put a sketch on that plane.
From the create panel dropdown choose Project/Include--> intersect. Then use the body option and click your solid. You can then measure the area of the area as shown in the image below.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
