Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Exporting Custom Machine
1 REPLY 1
rishik_thimm
90 Views, 1 Reply
I am trying to export a custom CNC Mill I built through the Machine Builder in the manufacture mode of Fusion 360. Whenever I export it, only the CAD part is getting exported without the machine configurations and the movements of the machine. How do I export the machine and in which file format (it is currently saved on my local device) so that someone else can also use it for machine simulation on their own desktop?
1 REPLY 1
kellings
in reply to: rishik_thimm
Hi @rishik_thimm If you switch to the manufacture workspace, you will see a Manage panel. On the Manage panel you will see a Machine Library command. Then you will see the different locations where you may have stored your machine. You can export a machine from there.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
