Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Electronics library for EDU Team??
1 REPLY 1
cnb4966
108 Views, 1 Reply
Are there any tutorials on sharing a library with a team/class in an educational setting?  I want to provide a library with custom title block and a few components.  In the past, I posted the library file for them to import but now I found the tutorial on creating a managed library (link below).  I'm still a little confused if this is the best way to set it up.
https://help.autodesk.com/view/fusion360/ENU/?guid=ECD-USE-MG-LIB
1 REPLY 1
dan.banach
in reply to: cnb4966
Hi @cnb4966
Thanks for posting your question. Here is a link to a few Fusion 360 electronics library videos on YouTube - Fusion 360 channel. You can also engage directly with the Fusion 360 electronics team on the Fusion 360 Electronics forum.
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
