Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
j3ng2ST98
70 Views, 4 Replies
Drawing
I have a completed assembly file, I go to New drawing from design and it freezes.  I've tried multiple times, program is just crashed.  Can't click on tabs or anything.  It opens a white screen but doesn't generate the drawing view with border and titlebox.  I tried opening an old drawing it just freezes after I click a view on the screen.
4 REPLIES 4
j3ng2ST98
in reply to: j3ng2ST98
I have the downloaded version, most updated, my graphics driver is also most updated.  Creating a new drawing is still freezing and crashing the program.  Any thoughts?
kellings
Hi @j3ng2ST98 Can you tell me the steps you used to update your graphics driver? Where did you start to do that process?
Can you go to fusion.online.autodesk.com and login to Fusion in a browser and try to make a drawing of the file there? I want to try to see if this is file related or hardware related, and that will be a good check to help us figure out where the problem is.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
j3ng2ST98
in reply to: kellings
I didn't take steps to update the driver, my tech support logged in as admin and checked for updates and it said the graphics driver was up to date and they redownloaded the desktop version of fusion 360 for me and it still does the crashing thing when going into drawing mode from an assembly file.
kellings
Did you test by going to fusion.online.Autodesk.com and trying to create the drawing there? If not, can you please try that? It will be a big help in tracking down your issue.
Kevin
Kevin Ellingson
You've got Fusion.
