Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
dont want to roughing when i have a hole straight through
1 REPLY 1
03any01
81 Views, 1 Reply
1 REPLY 1
kellings
in reply to: 03any01
Edit your setup. You will see an option called Spun Profile. Check that box and Fusion will ignore those features that are to be milling for the turning operations.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
