Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Creating a surface along 2 curves for splitting a solid body
5 REPLIES 5
padgettg
205 Views, 5 Replies
Hey all,
I designed an aerofoil for a car, and I'd like to create a mold in order to make the wing in carbon fiber.
I surrounded the wing with a box, split the box to create a cavity, but now I can't seem to figure out how to split the box mold into 2 separate parts.
The overall plan is to layup carbon onto both parts, join them together, and trim down the excess flanges.
Thank you!
5 REPLIES 5
kellings
in reply to: padgettg
Hi @padgettg Do you just need to split the mold, or do you need to split the mold in a particular way, like having it follow the lines of the wing?
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
padgettg
in reply to: kellings
Yes,
I'm struggling with splitting the box following the front and back lines of the wing (from the teardrop aerofoil shape)
kellings
Sorry, I see you wrote that right in your title now.
You will need to create a surface in the shape you want and use that as a split line. Is it possible for you to share the file here?
Kevin Ellingson
padgettg
Absolutely!
I'm attaching it here as a fusion file, as well as a step file just incase;
Pretty simple organization in the file: body 1 is the wing shape, body 2 is the mold shape.
Thanks!
kellings
Hi @padgettg I didn't get this to fully work, but I thought I would attach what I did so you could see and you could play around with it. When I created the surface offset, I couldn't get the surface to stitch properly without adding some tolerance. I'm not sure if there is a surface continuity issue with the original wing.
I created an offset surface of 0" using the bottom face of the wing. Then I created a ruled surface going perpendicular to the mold faces. For some of the surfaces I could use surface normal, and for some of them I had to use direction. I can split the body with the surface, or I can subtract the wing from the mold, but I can't do both. I suspect that is because of those surface deviation values I mentioned earlier.
Hopefully this helps to move you forward a bit.
Kevin
Kevin Ellingson
You've got Fusion.
